QUOTE(lapuwali @ Jun 1 2004, 11:33 AM)
skline, how are you determining the dizzy is 90d off? If you're looking at the rotor and saying "that's not where No1 is on my other 914...", look and see if the No1 plug wire is attached to the post you think it should be. If the No1 plug is attached to the post where the rotor is pointing at TDC on No1, then it's not 90d "off", it's just rotated 90d from the "normal" orientation, which means the distributor drive gear is 90d off from the "normal" orientation, but as long as the plug wires are arranged to match, no problem.
It's 90 deg. CW from the "mark" on the dizzy housing that indicates where #1 is supposed to be. It appears to be exactly 90 deg. out, and it did run, so maybe I shouldn't "F" with it and just watch the rockers for the valve adjustment. Let's put it this way, if the front of the engine is 12:00, the rotor is pointing at approx. 2:00 on this engine when the TDC marks are aligned. My 2.0L that will be going in my '73 is pointing approx. 11:00 with the TDC marks aligned. I'm guessing that as long as the everything's firing in the correct order it doesn't really matter.
