QUOTE(Mueller @ Jun 2 2004, 11:51 AM)
do you mind if I bleed the brakes?
Ahhh, it all starts so innocently doesn't it. Can I bleed the brakes? What size is this Master Cylinder - oh, 17mm. Well, we ought to swap that out for a 19mm unit. That will be quick and easy. Maybe change out the porportioning valve for a 'T' while I'm at it. And by the way, the brake pedal felt a little rough - maybe the pedal cluster needs rebuilding with some bronze bushings. And as long as I'm at it.......... Before you know it, out comes the plasma cutter......
Demick
