QUOTE(airsix @ Apr 18 2003, 02:54 PM)
QUOTE(anthony @ Apr 18 2003, 02:37 PM)
I don't think it matters if the stamping is forward/back, as long as you follow the same direction it was broke in.
It seems that if you respect the L/R designation, it shouldn't matter whether the stamp is installed in the front or the rear because either way the bar is still twisting in the same direction. Am I visualizing that correctly?
Yes, you are visualizing correctly.
-Ben M.
ps - I put them in with the stamping at the rear...so you can SEE it.
Thank you for that. I realize now that the rotation is the same as long as the side is remembered. My mistake.
When I've bought used bars in the past, I always asked the owner to indicate the direction they had been installed.
So left is left and right is right, stick 'em in. Takes a little of the fear out of buying used bars as long as you know the side it came out of.
I bet that debate has as much serious information as the classic 'cold glass flows
cause old windows are thicker at the bottom' argument.
There are some pretty knowledgeable hombres over there. If you think its a hollow (pun intended) argument, bring it up over there and then try your statement. I'll watch from here.
