Tman914
May 31 2011, 07:42 AM
Looking to change tire size from 185 x65 x15 to a 195x60 x15 will this work ?
Thestigz06
May 31 2011, 07:57 AM
QUOTE(Tman914 @ May 31 2011, 06:42 AM)
just be careful hitting like drieways at an odd angle cuz it rubs a bit on the front fenders but other then that youre fine.
damesandhotrods
May 31 2011, 08:19 AM
At the moment I am running 195x65x15 in the front and 205x65x15 in the rear on 4 lug Fuchs.
underthetire
May 31 2011, 08:49 AM
Probably, but you didn't specify what rims you are running. I had 195/60 on my Rivi's, and even a 205 in the rear. Don't recommend the 205 on narrow rims. I run 205/50/16's on 16X7's all the way around now.
Tman914
May 31 2011, 08:51 AM
Running 4 lug Fuchs i know there 15"x 5 1/2
TheCabinetmaker
May 31 2011, 10:18 AM
The 195's will not hit anywhere. I ran 205x50 on my pedrinis and they rubbed slightly at full turn. 205x60 did not rub.
Tman914
May 31 2011, 12:35 PM
Thanks Guys
avidfanjpl
May 31 2011, 01:12 PM
Curt has it down!
205/60-15 do not rub, but make sure your springs don't sag.
John
eric9144
May 31 2011, 02:15 PM
Been running 205/60/15s on my Fuchs for years, no issues w rubbing at all...you will see the speedo spin a bit higher than it should be but if you're really worried about that it can be adjusted by a speedo shop.
Dave_Darling
May 31 2011, 02:29 PM
195/50-15 on Fuchs rubbed aft of the shock tower in the front fenders when the steering wheel was turned full lock. It wasn't a real issue because the wheel never gets cranked over that far when moving quickly, but you could definitely see it was rubbing.
All these cars vary slightly, so YMMV.
--DD
Drums66
Jun 1 2011, 04:48 PM
gothspeed
Jun 1 2011, 05:04 PM
I ran 195/60-15 on my old creamsicle LE with original Mahle wheels. The tires looked and fit perfectly
