QUOTE(Prospectfarms @ Jun 5 2011, 02:00 PM)
Update:
Here's what I am presently dealing with:
-1.7 D-jet
-Good compression all 4
-Tune-up, dwell, timing and valves set to specifications per Haynes.
-No obvious vacuum hoses leak (air/idle screw adjustment now affects idle speed.)
-Starts at 900 RPM, after 5 minutes it rises to 1500 RPM. Idle is steady and smooth.
-Clamping the AAR hose on supply side bring idle back down to 900.
-Disconnecting and plugging manifold connections has no significant effect.
-At 15 minutes run time, the engine begins to miss and then stalls after about 2 minutes. Reving motor and/or unclamping AAR doesn't prevent stall.
-Exhaust smells rich when engine stalls--assume flooding.
Per Haynes FI trouble shooting section: "engine starts cold then stalls:" = MAPS or CHT.
This is consistent with the opinions of several members here.
Tomorrow, I will:
-Check CHT resistance value
-Go through diagnostic procedure on MPS.
Anything else?
Where will I find a serviceable MPS if mine's kaput?
Pulled ECU and tested resistance of CHT and MAP at pin harness per Anders.
CHT resistance 2.54K (within a few OHM's of spec.) MAP was right on spec.
My brother suggested an unseen leak at throttle body or manifold that would expand with engine temperature.
Next on list is to test TPS and inspect throttle body for unseen leaks.
I'll keep digging.
All these static tests leave me wondering...
To recap, I'm looking for the condition that causes my 1.7 FI to stall out at a certain operating temperature. The idle is good for about 15 minutes and then it starts hunting, the RPM's drop and it stalls. After checking the plugs, and smelling the exhaust, I believe it is a flooding condition. The functions and behaviors of the FI components (the "likely suspects") also argue that any massive failure of this kind would result in flooding.
The possibilities are almost limitless and I wont discount any of them, but I feel it is one of three: 1. CHT thermistor never warms up. 2. ECU issue. or 3. TBS is doing something I don't understand.
As I said, the static testing only gets me a spec at room temp, and especially for the CHT, this is not sufficient. If it is not decreasing resistance as the engine approaches warm, the mix could conceivably become too rich to run -- I guess.
Its the sudden onset of the problem that really confuses me. it would seem that any falure of a FI component brought on by heat, would show some progression. This problem comes on all at once.
I'm considering splicing a pigtail to the CHT wire and grounding that when the engine is about to stall. Grounding the CHT would essentially render it invisible to the ECU. Good / bad idea?
