The time has come that I want to change out my 5 lug solid rotors to ventilated rotors all the way around.
Fronts: I am adding alumninum Brembos upfront (I have 3" struts). Will I be able to use the same hats and bolts that are on my solid rotors with the ventilated rotors? I also have 16x7fuchs, narrow body.
Will changing the rotors effect the front end alignment?
Rears: I am going to purchase a vent kit for my rear stock calipers from Eric which require 4mm to be turned off a stock 911 ventilated rotor.
If I take the rotors to a brake or machine shop and ask them to take off 4mm will that be precise enough info for them to know what to do? I presume taking 4mm off gives a little bit of wiggle room for clearances.
