Djet injectors are powerd through resistors as well, they are just internal to the ECU. somewhere between 6-8 ohm in all the ECUs i have torn apart.
I suspect that L-jet injectors could be made to work with a D-Jet system, but why would you want to? If you are going to go so far as to run non stock parts, hack up a wiring harness, and deal with having to tune d-jet around the new injectors you might as well just install Megasquirt.
QUOTE(Cap'n Krusty @ Jun 1 2011, 04:32 PM)
Enough speculation!
Black D-jet injectors are the same as the yellow ones. Early T3 and T4 had black which morphed into yellow ones as production went on. Green are 2.0, Blue are Mercedes Benz. Porsche and VW L-jet injectors are various shades of light blue, and may work across the board on L-jet VW cars and Porsche 914s, but they're NOT all the same, so it's wise to use the correct P/N for your engine. 912Es use grey injectors, and L-jet 928s have tan ones. L-jet injectors are powered up through a resistor block, and should NOT be used with the 12v power used to power D-jet injectors.
The Cap'n
