Trekkor
Jun 7 2004, 09:11 PM
What is it?
Thanks.
Brad Roberts
Jun 7 2004, 09:13 PM
That number doesnt do us much good. We need the 901 *_ _ /_ _* number.
We aleady discussed it being a early 2.0 engine. Any info beyond that and it has to be torn down or a spec sheet found on the engine.
B
campbellcj
Jun 7 2004, 09:18 PM
Definitely get the engine type number (vs the engine serial number). Although as B alluded to, the 60's and 70's engines are now old enough where SO many of them have been rebuilt (i.e. dicked-with) that you cannot take anything for granted. Unfortunately the only way to tell for sure what is in one of these puppies is to tear it down and check the part numbers and/or mic everything...
I got "lucky" relatively speaking with the engine I bought back in 2002, but I still have no clue what it really is.
Trekkor
Jun 7 2004, 09:23 PM
engine # is in the title- also here now
901-06-8372
Brad Roberts
Jun 7 2004, 09:33 PM
NO.. it's the 901/XX number that you gave me. 901/62 or something.
B
Trekkor
Jun 7 2004, 09:44 PM
here's the other #
campbellcj
Jun 7 2004, 10:00 PM
I'm not sure what to make of the 3-digit type number (after the 911/) but the 911/67 engine was a 2.4 911T Euro Sportamatic! (Same specs as the regular 911/57 2.4T Euro in 72/73.) It was a carbed, low compression engine built for good street torque and emissions compliance.
But as mentioned above...the numbers on the outside mean relatively little these days. Unless you have "high-confidence" documentation about any and all rebuilds, then the number just tells you what it "started" life as 30 years ago...
seanery
Jun 7 2004, 10:01 PM
some of those are now going on 40 years
Brad Roberts
Jun 7 2004, 10:02 PM
Yes. It tells us what the CASE started life as. It tells us nothing about the cams/heads/P+C's/cam towers..
B
campbellcj
Jun 7 2004, 10:07 PM
QUOTE(seanery @ Jun 7 2004, 09:01 PM)
Aw...f* you Sean...thanks for reminding me that I was born when only a few hundred 911's had been built as of yet
(Gonna be 38 this year and I don't feel a day over 37).
Trekkor
Jun 7 2004, 10:10 PM
Going to take a peek on thurs PM.
Will check chain tensioning and adjust valves.
Have new plugs, wires and coil to freshen it up.
Plan on starting it!
Trekkor
Jun 7 2004, 10:15 PM
Don't know if I told you this, I believe this motor was built by Vince of V-Mar Off Road Racing. He's the rasta racer with the surfboard mounted to his desert race car. I put out an e-mail to him last week to help me out but he doesn't reply yet.
campbellcj
Jun 7 2004, 10:26 PM
According to the sources I have, if it is really a 72/73 2.4TV ROW Sporto engine then the engine number should be 653 9001-(something)
The engine type 901/06 was a 1967 911 "regular" (non-S) 2.0 w/ Webers...and their serial numbers were 911 001 thru 911-190. Maybe that's what it is, i.e. # 911-067?
A big tip off would be an aluminum case vs. magnesium.
Rusty
Jun 8 2004, 03:52 AM
I already posted this info in the other thread.
You posted the serial number. The case serial number indicates it's a '67 911 case, model number 901/06. It should be an aluminum case. The picture you posted looks like aluminum, but that could be just the light.
What's it's been built into... God only knows.
-Lawrence
Eric_Shea
Jun 8 2004, 06:33 AM
the picture shows the serial number located on the vertical fan housing support. Here's the puzzling part:
This reads more
like a "type" number telling us it may have started life as a 67/68 130hp 2.0 liter. The puzzling part is the 8372. I've "
never" seen a 911 engine with any code behind the engine type number.
To find the "real" type number you need to look on the horizontal surface behind the engine serial number. It should read 901/06 (with the slash and without any other numbers behind it) if that's what it is. I suspect the 901-06-8372 number is cast into the top of the fan shroud. This is simply a casting number for the shroud. Lots-o-people mistake this for an engine type/serial number.
Based on the serial number alone you may have an engine as early as a 901/01 (65) or a nice 160hp "S" engine the 901/02 (keep your fingers crossed).
Scrape off some grease and grime and get us the real "type" number (right behind that serial number)
brant
Jun 8 2004, 08:56 AM
Trekkor,
also check to see if the cooling fins on the cylinders are iron or alloy... Usually you can see the rust if they are iron.. or put a magnet on them to verify...
this will help ID what might be in it for pistons/cylinders at least....
brant
