Rog914
Jun 8 2004, 10:18 AM
Found this on the www awhile back and thought I'd post here to see what you all think.
Break-in secretsWhat do you think, Brad, Jake, anybody.
Ralph
74 2.0
Rog914
Jun 8 2004, 03:13 PM
Edited post to make easier to get to website
SpecialK
Jun 8 2004, 06:15 PM
Hmmm....It makes sense in reference to the rings, but totally omits concern with breaking in the cam and lifters.
definitely need Jake or Brads input on this one.
jarbuthnot
Jun 8 2004, 07:04 PM
This is very timely. I hope to get mine back with a new 2.0 engine next week; need some additional parts (my mechanic has that dreaded disease discussed in earlier threads and I'm glad he does). Anyway, when I drive it home, which is 40 miles of twisty, hilly road with some straight, should I drive as I normally do - at the top of the range for each gear before I shift up?
From reading the article, it sounds like I should. And does that mean that's all I have to do? My mechanic will be doing the first oil change, etc. before I get it.
Jake Raby
Jun 8 2004, 07:20 PM
1- Crank for oil pressure
2- ensure the engine is actually ready to fire up
3- fire it up and look for leaks and listen for sounds
4- let it run at no les than 2500 RPM for atleast a half hour, DO NOT let it idle!
6- Shut it down and let it cool off completely, then let it run again for 15-20 minutes and then you can let it idle.
7- install it into the car, drive it just like you normally would. If you drive it a long distance vary your speed.... Don't be afraid to wind it up, if its gonna scatter it'll do it whether you pussyfoot it or not..
I fire them up and break them in and take'em straight to redline and beat on them for 8 hours.
swood
Jun 8 2004, 07:25 PM
Is that for non ceramic lifters or all types?
jarbuthnot
Jun 8 2004, 07:38 PM
QUOTE(Jake Raby @ Jun 8 2004, 09:20 PM)
Thanks Jake. My mechanic is going to do items 1-7 1/3 and I'm doing the rest. Just didn't know if I had to be careful on the way home. On the road home, I have no choice but to vary my speed.
Jake Raby
Jun 8 2004, 09:50 PM
With ceramic lifters just crank the engine and let it idle right off the bat. They need no break in. They are indestructible.
