tscrihfield
Jun 2 2011, 09:00 PM
So I have a concern. During the inspection of a crank I recently obtained I found discoloration (much like gun blue) on the area outside of the middle main journal. I'm not as versatile in air-cooled engines and im not sure if this is normal??? All of the journals mic'd fine and well within spec. This is not a good sign when dealing with most engines I know, but I am wondering if this is normal. Would this be a replace scenario?
tscrihfield
Jun 2 2011, 09:02 PM
To clarify it is in the thrust bearing area, not on the actual journal itself.
r_towle
Jun 2 2011, 09:05 PM
Not sure where you are talking about.
Is this a used crank?
You may want to get it polished.
Rich
Jake Raby
Totally normal if its what I believe that it is.. I have seen NOS cranks for TIV engines have this discoloration.
post some pics.
tscrihfield
Jun 3 2011, 08:02 AM
QUOTE(Jake Raby @ Jun 2 2011, 11:05 PM)
post some pics.
Will post pictures when I get home. This is a stock 2 liter crank and it is used, but the journals are in terrific shape.
tscrihfield
Jun 3 2011, 03:32 PM
QUOTE(tscrihfield @ Jun 3 2011, 10:02 AM)
post some pics.
This is the area of discoloration... Let me know what you think. I will have it polished anyway but this is my only area of concern.
Don M
Jun 4 2011, 07:18 AM
appears to be trace discoloration from factory induction hardening process, as long as size, finish and run-out are acceptable not a problem
tscrihfield
Jun 4 2011, 08:39 AM
QUOTE(Don M @ Jun 4 2011, 09:18 AM)
Thanks! Glad to hear that! I thought it might have been from heat treating but wasn't so sure!
