sorry, forgot the pictures
o.k. so yes, i have both the d-jet bosh manual and have been over the anders site etc etc.
the problem was getting a fast idle down, -
when ecu was set at the middle setting, idle was about 1800.
when trying to adjust idle with idle screw on throttle body, it would decrease but upon getting it to about 1500 rpm then an idle hunting would begin- if ecu adj was moved 2-3 clicks to the rich side, then idle would smooth out- doing this 3x idle was able to hold with no hunting at about 1000-1100 rpm.
it is possible the ECU is just initially on the lean side? everything i have read including the bosch book indicates that a lean idle when warm can cause the hunting.
- AAR is closing off correctly when warm - checked
- timing static at tdc, the 27d-at 3500 rpm right on
- valves recently set by experienced porsche mechanic-
- yes new vacuum hoses and checked all possible vacuum leaks
- vac advance is not connected- left as was from the factory in 75- my throttle body has one vac attachment- for retard as was case for 75.
- if vacuum was the cause of the idle hunt, changing the mix would not correct the problem===
I guess the only way to know if the fuel/air mix setting is where is should be is with the propper equipment- tester??
The inline resistor was added because the CHT was lower than should be when warm-
if i had over corrected it - would it cause the plugs to foul or burn to the grey as in these pictures?
thanks for the input
