QUOTE(Tom_T @ Jun 3 2011, 03:22 PM)
Best check that you've got a good ground strap & connections from the transaxle to the chassis (stud on underside of rear trunk), otherwise your acc. cable becomes the ground & fries!
You do have a grond strap there, don't you!?
I have a good ground strap for the tranny. I did just discover after calling a friend that is a mechanic that I have a cable from a 4 cylinder because mine doesn't go to the tranny. I'm still going to make sure it's not rubbing on anything.
