1] Rear window {uninstalled excellent tinted} $90 shipped
1] Rear window (clear)$70 shipped
1] pass glass O.E.M. factory tint $40 shipped
1] driver wing glass O.E.M. factory tint $25 shipped
1] windshield (I will get out of attic to check details soon)
LIGHTING & ELECTRICAL
1] set of very nice hella O.E. U.S. spec. tail light lens w/buckets and special attaching nuts $145 shipped
1] front euro turn signal light conversion kit (instructions, bulb sockets, dividers, etc. . .) everything needed to convert to euro but the lens $20 shipped
1] front lens w/ (2) seals $20 shipped
1] very nice "Porsche" reflective tail light section $165 shipped
1] set of chromed driving light grills, fins 100%, chrome shot $60 shipped
1] side marker light base $15 shipped
1] electric trunck release solenoid used with or w/out above reflector $50 shipped
1] 1972 d-jet relay board $30 shipped
1] fuel sending unit w/misc. attaching hardware $75 shipped
1] cut alt harness (good 4 alt plug body or pigtail) $15 shipped
DRIVETRAIN
1] O.E. steelie beauty ring $30 shipped
12] unobtainium "Dan Gurney/western rim" shouldered lug bolts $30 shipped
1] set of stub axles with couple extra incomplete c.v. misc. axles & joints/parts $30 + shipping
1] set of complete used axels (ea. Has stub axle, axle, inner& outer joint good boots) $75 + shipping
4] brand new in wrapping, c.v. joint gasket seals, hard to find when you need them, all 4 $30 shipped
1] set of 911 trans sport mounts $50 shipped
2] main e-brake brake cables very nice condition $ 75 shipped
ENGINE
1] Header w/ glass pack -after heat exchangers
2] unused 96mm "rimco bored/honed" Mahle cylinders light fin damage $75 each shipped
1] complete engine set of 1.7rockers for swivel conversion (no swivels or machining) $80 shippe
4] 1.7 high compression "euro" pistons and wrist pins $95 shipped
4] 96mm flat top pistons, pins and rings w/ rings $85 shipped
4] 1.7 yellow injectors & hold downs $50 shipped
1] j-tube $25 shipped
1] set of decent j-tube tin seals $20 shipped
1] 2 new cork, 1 rubber type valve cover gaskets, misc. engine gaskets, etc. . . $25 1] 1972 d-jet relay board $30 shipped
1] good used starter $65 shipped
1] huge bundle of misc. Nice o.e. braided hoses $25 shipped
1] ribbed/insulated heat tube $20 shipped
1] 2.0 throttle body w/ tps $ 75 shipped
1] 2.0 rubber throttle body to air cleaner sealing piece w/ clamp $25 shipped
1] NON sending unit oil cover and screen $20 shipped
1] oil cap $10 shipped
1] rear brake caliper $25 shipped
2] good used oil pumps $30 each shipped shipped or $50 both shipped
1] evaporative canister with securing hardware $30 shipped
INTERIOR
1] set of "butt breathing" fabric seat inserts, both w/ good sensors {worn material} great to temporary swap in for hot sweaty days or long drives $65 shipped
1] set of used crown vic power lock solenoids $30 shipped shipped
1] H/D power lock solenoid new $25 shipped1] Custom steel/vinyl covered 6 gauge panel w/lights and rocker switch area and misc. parts . . . unfinished project. . . $35 shipped shipped
1] about 20 ft. of special twisted CHT wire (I'll measure soon) $25 shipped shipped
1] used turn signal switch (no harness)$15 shipped shipped
1] Custom vinyl covered steel 6 gauge console face panel, unfinished project. Set up for rocker switches and multiple lighting, comes with misc. add your gauge selection and finish $50 shipped
1] O.E. walnut shift knob typical lens cracking but not too bad $30 shipped
EXTERIOR
1] targa top w/ non opening sun roof. Great topless compromise for cool sunny days $75 + shipping
1] unused/brand new, trunk gas strut kit, will add a set of used bolt on struts if wanted $75 shipped
1] fuel sending unit w/ extra ring & mounting hardware misc. $75 shipped
1] engine trunk lid complete w/ grill solid west coast part $75 + shipping
http://www.youtube.com/watch?v=2FM1Fnzyv8I
- it's NOT ok to contact this poster with services or other commercial interests
