mtburman
Jun 5 2011, 10:18 AM
Does anyone have specs for A/C hoses? Upgrading to Sanden compressor, want to replace hoses but need to ensure I order the correct end fittings since they are custom hoses.
Larry.Hubby
Jun 5 2011, 08:43 PM
Have a look at the on-line catalog of Vintage Air:
http://www.vintageair.com/catalog.asp . They have both hard and soft lines and fittings for pretty much everything.
charliew
Jun 6 2011, 04:33 PM
There is also a vw new air to old vw's place in calif. Google vw ac. I met Jack Chisenhall in college and ran around with his brother and he is good but not as close as the guy in the west.
SLITS
Jun 6 2011, 07:54 PM
Most A/C shops that I encountered can use your fittings to make new hoses (assumption is that you have the old ones).
mtburman
Jun 6 2011, 09:01 PM
got them, AAPAK in phoenix, went in over lunch, out with new hoses. Sanden compressor fitted up. Engine shelf mess cleaned up, may need to add metal depending on compressor fit. Pulling condenser out to have look at metal up front.
Also thinking of replacing clutch since motor is out.
