QUOTE(ruddyboys @ Jun 9 2004, 10:20 AM)
Champion plugs from flaps, crapy 005 dizzy, regular unleaded gas, plugs were oily untill most resent rebuild, mixture screw o rings to big now they are sooty, was getting black oily crap out of the tail pipe, now seems to be clean, my jets are Main 115, Idle 50 not sure the air. Also dual weber 40 IDFs.
well - there are lots of Champion plugs and i (personally) don't like any of them ... find yourself some nice Bosch W7 copper plugs or the NGK equivalent ^6, maybe) - nothing colder. -- sorry, i can't remember the reach code and interestingly, there are no spark plug designations in the Spec Book. for some reaon, i'm remembering W7BC...
on the distributor i'll assome you meant 009 - an 050 would be a good choice, and a stock dizzy would be some flavor of 205...
all bets are of until you get the right O-rings for the mixture and air pleed screws ...
50 seems pretty small for an idle, if correct, and 115 sounds small for a main -- but i don't know your displacement, nor what kind of cam you're using.
i will assume from your location that you're near sea level ...
