QUOTE(newdeal2 @ Jun 9 2004, 12:28 PM)
I am planning to remove my 2.0 and I am leaning towards the Pelican article on engine removal. Here are my questions:
1] Safest way to keep the front of the car stable when I am jacking up the back. I assume it's safest to leave the wheels on the front.
2] Any other options besides the furniture cart?
3] Most of the floor jacks I have seen only go up to about 20" or so...is this enough? This is also the safe limit of my jack stands [3 ton SUV].
4]Is there an easier way to get to remove the CV's other than on the ground prior to lifting the car?
5]Will it be better to remove the HC's and exhaust prior to avoid damage?
Any pointers will be appreciated.
1. I just put chocks in front and behind the front wheels.
2. I used a furniture cart. You might want to put a piece of wood, on the cart, under the front of the engine to match the angle the car will be when you go to unbolt the engine/tranny.
3. One of mine says something like 15.25". I had no real problem. I even left the rear valance on. But did take off the air filter housing.
4. I raise the car up and use e-brake to hold everything. That way I can spin the wheels to give as much access to the CV bolts as possible.
5. I left the HE's and muffler attached. No problems. Just make sure the engine is not resting on an exchanger tube while it is on the cart.
I also had the engine tin catch on the suspension ear bolt.
