pman
Jun 9 2004, 04:30 PM
Changed out my Turn signal em flasher relay for a 1974 - 914 today. Everything works fine with the key switched on. Once you start the car, the relay makes a buzzing sound when the flashers are not activated, and the red em switch stays lit. No buzzing when they are activated. I also changed the W/S wiper, washer switch today. Any solutions? Also, the new turn signal em switch was a different size from the original. Replaced with R914 618 303 11
pman
Jun 9 2004, 07:36 PM
Help please?
smrz914
Jun 9 2004, 07:40 PM
do all the lights work?
pman
Jun 9 2004, 08:01 PM
Yes, everything is working.
smrz914
Jun 9 2004, 08:12 PM
The internal resestance in the switch might be different then the stock one, and so the signal to the relay is not clear. It's a long shot but it's all i can think of. I had the same thing happen and thought that my alternator was puting out to many volts (14.5) and doing something screwy with the relay. Then I looked in my trunk and found that one of my taillights was disconnected. connected it and it fixed the problem. You might want to check the connections.
pman
Jun 9 2004, 08:18 PM
Thanks, we'll check it out in the morning. Hope we can fine the problem.
Paul
