The 74 that I am trying to get running actually has an issue with the Seat Belt Relay under the passenger seat. When I turn the key to start, all I get is a nice,
"Click" from the relay. After reading other posts, I will splice the large Yellow and Yellow/Red wires together, and by-pass the thing completely. Since this car has
not been started in several years, I am interested in knowing the sequence of
events this relay controls. It is my understanding that the fuel pump should get
power and run for a brief time when the ignition is turned on, then with the movement of the key to the start position, the starter should engage. Can anyone confirm if the Seat Belt Relay interupts the fuel pump power in addition to
the starter?
Thanks!
Step by step, I am getting closer to putting another one back on the road....
