QUOTE(trekkor @ Jun 13 2004, 10:59 PM)
I will install 200# rear springs to help balance the car.
i don't think so, sir ....
after talking to you today, it seems the car needs some serious spring in the rear to balanced out.
you got piggy understeer today, couldn't set the bar on full soft (cause brake lines are in the way), but even with full soft, now that you have sticky tires, you'll have to step up on the rear spring rate considerably to be able to actually USE your sway bar. a rear sway bar will help offset some ...
problem is, if you go too stiff in the front (sway bar wise) you'll have to go REALLY stiff in the back to get it balanced, which is good for road racing, but will make the car very *jumpy* on a AX course ...
anywho, i suggest, get the rear bar, then pump up your rear spring rate until the front bar is actually useable.
you made a big leap with those sticky tires and *monster* front bar, now you neeed to balance the car right.
then, you need to learn how to drive!
Andy
j/k of course. hey you beat me by 1 sec. today!
