matteyp
Jun 8 2011, 02:10 PM
Can someone tell me how to tighten my alternator belt? For sone reason when i try to spin my motor and put at at tdc it motor will not spin. I think this would be due to a lose belt correct? Some help would be appreciated. Thanks
Matt
URY914
Jun 8 2011, 02:14 PM
Nope, nothing to due with the belt being tight.
Jeffs9146
Jun 8 2011, 02:21 PM
If you are trying to spin your motor using the alt bolt this can happen! Use your crank bolt to spin the motor.
You may need to replace the belt or remove a shim from the pully to get the old belt tight.
matteyp
Jun 8 2011, 02:36 PM
Motor is very hard to turn using the crank bolt. Is this normal?
IronHillRestorations
Jun 8 2011, 02:42 PM
Remove the spark plugs, and your engine should turn over easily.
nathansnathan
Jun 8 2011, 03:35 PM
I've never been a fan of turning the engine over by the bolts that hold th fan on. Those have a specific torque value and I can't see how that wouldn't be affected. Plus I turn the engine over CC when I do my valves so that wouldn't work doubly.
Even with the belt tightened properly, depending on the engine's compression, temperature, oil weight, etc, it can make the belt slip.
What you do is take the slack out of the belt (supposed to be 5/8" slack about) by pulling up on the top of the belt toward the fan housing. By this method you will be able to get it past the compression points.
Cap'n Krusty
Jun 8 2011, 04:41 PM
QUOTE(Jeffs9146 @ Jun 8 2011, 01:21 PM)
Good luck looking for the shims. There aren't any.
The Cap'n
yeahmag
Jun 8 2011, 05:02 PM
The easy way to do this is jack one side up so the rear wheel on just one side is in the air. Put the car in 5th gear and turn the wheel (that's in the air).
Easy.
Jeffs9146
Jun 8 2011, 05:27 PM
I keep forgeting that not everyone has a 6
QUOTE(Cap'n Krusty @ Jun 8 2011, 03:41 PM)
The Cap'n
messix
Jun 8 2011, 05:38 PM
chock wheels [block them so the car can't roll away] release e-brake, jack drivers side rear wheel up so it is not touching the ground, put transmission in a gear [5th works fine] you should be able to move the rear wheel and that will turn the engine. it will NOT turn "easy' but it will turn. if that is too hard to turn remove the spark plugs then it will turn more easy.
matteyp
Jun 8 2011, 08:25 PM
Thanks, figured that out. Car starts now but has no power. Assuming it needs to be timed with a light. Can someone go over how to do that? Thanks
Matt
McMark
Jun 9 2011, 12:00 AM
Pull and plug the vac hoses that go to the distributor.
Loosen the 10mm nut on the distributor clamp.
Hook up your timing light.
Rev the engine to 3500 and set it to the red mark on the fan.
That's the short version. You have a Haynes manual, right?
matteyp
Jun 9 2011, 01:16 AM
Ok so when u say rev the engine to 3500 and set it to the red mark, what exactly am I setting to the red mark? Also the mark on my fan is white. Are u talking about TDC here? Thanks for the help
SLITS
Jun 9 2011, 07:03 AM
In ideal times, the TDC mark is painted white and the 27 degree BTDC mark is painted red. The red mark is about 4-5 impeller blades to the RIGHT of TDC FACING the impeller.
Start engine ... have someone hold 3000 RPM while you twist the distributor to line up the red mark in the notch of the impeller housing.
If you haven't timed an engine before, buy the Haynes manual and read it or get help.
nathansnathan
Jun 9 2011, 07:34 AM
Dave_Darling
Jun 9 2011, 06:35 PM
McMark
Jun 9 2011, 09:55 PM
Do you have the Haynes?
messix
Jun 9 2011, 10:11 PM
matteyp
Jun 11 2011, 11:52 PM
Thanks for the help guys
