QUOTE(c12croft @ Jun 9 2011, 02:25 PM)
I got to mitigate this smell before I get put out in the rain. I need my garage space . The car sat comfy in garage with only a 1/4 tank of gas for 3 yrs and did not smell of gas. Now that tank is mostly full (no way overflowing) it smells like I'm storing a boatload of molitov cocktails,
Could there be a seam split in tank, just at a higher level so it only leaks when tank is full? (albeit no visible drips to be found, I had a large piece of cardboard beneath the tank to identify any drips).
Fist off, get it out on the road and use up the gas, get it down to a 1/4 or less. Or drain it into gas cans. That will not only solve the smell issue in the garage (most likely), but will make the tank a lot lighter for when you lift it out to check for rust.
The felt/carpet pads under (and behind) the tank like to retain water, over the years they rub the paint off the tank, then when they get wet, they cause rust. Symptoms point to the rear pad, about halfway up the side of the tank.
It sounds like it's time to pull the tank and check for pinholes at those spots. Change out all the hoses while you're in there. One time I found a DAPO had put hose marked "Fuel Vapor" under there, it was all swelled up and about to burst... That time it was really dripping once I put any gas in it.
