My car is a '73 914-4 2L FI, and here is a description of the problem:
When the engine becomes hot, the car has less and less power at low RPM. On street corners, I have to rev the engine above 2000 RPM to get going without stalling it. When the engine is cold, this is not a problem. Also, if I have been driving for quite a while and the engine stalls, it will only re-start on compression. Cranking it won't start it.
Last year, I fixed many things in the car, and I thought this problem would be resolved, but it hasn't been. Here is a list of parts that have been fixed:
- My 037 MPS was leaking, so I replaced it by a none leaking 049 MPS (0 280 100 049 MPS) that I re-calibrated. In order to do this, I brought the car on the dyno. While the car was on the dyno, we noticed that the engine "preferred" to run rich, and that it did not have that much torque at low RPM. For someone not accustomed to it, the car easily gives the feeling it is gonna stall when starting in 1st gear. It has always been so, but it seems even more so since I changed the MPS.
- I replaced the CHT. My 0 280 130 017 CHT was bad, so I replaced it with a 0 280 130 012 CHT, since the 0 280 130 017 is no longer available. I kept the ballast resistor in place.
- The injector seals have been replaced.
- The FI wiring harness has been replaced for a brand new one.
Any idea of what to check next?
