QUOTE(stugray @ Jun 10 2011, 04:24 PM)
Did it pop up 1 inch when you pulled the cable?
If so, it has a secondary latch like all cars in the front.
If it wont pop up at all, try having someone push down on it while you try to pull the cable.
If THAT does not work, the cable is broken or stuck, and you have to remove the front bumper. You will find a hole that you can access the latch with a screwdriver.
Stu
Thanks Stu that is what I am trying to find? the secondary latch?
