mgphoto
Jun 11 2011, 05:39 PM
Hello,
I bought an engine to use in my car while I am rebuilding my hi mileage 1.7.
I thought I might ask if anyone here has any knowledge of this motor?
Looks well taken care of, has some small problems to sort out.
Any info you may have I would appreciate.
Thanks,
Mike
mgphoto
Jun 11 2011, 11:50 PM
I found something odd, I am not sure but I believe it is an AC pulley located between the blower fan housing and the engine block.
Does anyone know for sure what this is for?
mgphoto
Jun 11 2011, 11:56 PM
Another oddity a small hole in the top of the air distributor housing just under the throttle body, see photo below.
Anybody know what this is for???
ejm
Jun 12 2011, 04:58 AM
That is an A/C pulley. The “hole” is a tube welded thru the plenum to reinforce it.
mgphoto
Jun 13 2011, 10:32 AM
QUOTE(ejm @ Jun 12 2011, 03:58 AM)
Thanks Ed, I can understand the tube in the plenum for support.
But, if the A/C belt fails the engine needs to be pulled and the fan housing removed??
Seems a bit extreme, is this a stock configuration?
Mike
Dave_Darling
Jun 13 2011, 11:31 AM
It's the standard dealer-installed AC setup, yes. But no, it's not factory. None of the regular 914s had AC from the factory.
And yes, it'd be a pain to change the AC belt.
--DD
mgphoto
Jun 13 2011, 01:48 PM
Thanks Dave.
I do have another question about the cooling flaps, they have been removed and I can see that the passenger side cooling tin has what looks like a slot, for what I assume is the hole for the A/C belt to compressor connection.
Because of unwanted heat entering the engine bay from this slot, I intend to replace the cooling tin but do I need to replace the cooling flaps and the bellows thermostat? I am located in the Los Angeles area, mostly a temperate climate, lows no lower that the 40's and high's in the 100's.
Also what cooling tin pieces are necessary in conjunction with the oil cooler, which relate to the cooling flaps?
Thanks for the insight.
Mike
Dave_Darling
Jun 13 2011, 03:54 PM
You absolutely positively need to have the flaps, particularly the one on the passenger's side! That is what ducts air down through the cooler; without it you will see high oil temps that cannot be fixed. This flap, in its open position, sits on top of the cooler on a piece of tin that fits around the cooler.
It is best to have all of the systems working correctly. And also to isolate the top of the engine bay from the bottom, which means plugging up the holes left by the AC installation.
You'll need a new right-side cylinder tin and you'll need to repair the engine shelf. And it sounds like you may need more bits. Check the parts diagrams on the Pelican site for an idea of what parts there are. (Haynes also has the same pictures, as does the factory manual.)
--DD
mgphoto
Jun 14 2011, 05:01 PM
OK next item!
I pulled the plugs and did not like what I saw, oily threads and black sooty centers.
This is a fuel injected motor so I assume that it is running very rich and oil is getting past the rings and valve guides.
Am I correct?
mgphoto
Jun 14 2011, 05:34 PM
QUOTE(mgphoto @ Jun 14 2011, 04:01 PM)
OK next item!
Am I correct?
Click to view attachmentPS: the plug is an NGK "R" BR6ES
anyone know the application of this plug? I am trying to get a handle on this engine.
Thanks,
Mike
