Hey everyone,
Forgive me if I didn't do a good enough search to find this answer, but I've got a teeny problem. My '72 shift lever shaft is twisting at the ball base, causing the shift knob to migrate closer to my leg and making it damn near impossible to shift into first or reverse, due to having to overcome the spring pressure and as a result the loose shaft will twist toward my leg and change the lever angle. I tore down the shifter assembly today hoping to find a loose bolt or something, but it appears that the shaft is pressed into the ball base? I didn't find any type of fastener that holds these two parts together. I saw on ebay that someone is selling just the ball base (lower shift lever), so I must assume these parts can come apart. Anyone have any ideas on tightening it back up or am I off to the auctioners to find a replacement shifter assembly, or worse spend $500+ on a shifter kit that I really don't want? Any advice would be great. Thanks!
