GLASS http://www.youtube.com/watch?v=7faRj7HcDtU
http://www.914world.com/bbs2/index.php?showtopic=128299
1] Rear window {uninstalled excellent tinted} $90 shipped
1] Rear window (clear)$70 shipped
1] pass glass O.E.M. factory tint $40 shipped
1] driver wing glass O.E.M. factory tint $25 shipped
1] windshield (I will get out of attic to check details soon)
1] targa top w/ non opening sun roof. Great topless compromise for cool sunny days $75 + shipping
LIGHTING & ELECTRICAL http://www.youtube.com/watch?v=9kBQ0qkE4tE
http://www.914world.com/bbs2/index.php?showtopic=128300
1] set of very nice hella O.E. U.S. spec. tail light lens w/buckets and special attaching nuts $145 shipped
1] front lens w/ (2) seals $20 shipped
1] very nice "Porsche" reflective tail light section $165 shipped
1] electric trunk release solenoid used with or w/out above reflector $50 shipped
1] set of chromed driving light grills, fins 100%, chrome shot $60 shipped
1] side marker light base $15 shipped
1] 1972 d-jet relay board $30 shipped
1] fuel sending unit w/ring & misc. attaching hardware $75 shipped
1] cut alt harness (good 4 alt plug body or pigtail) $15 shipped
1] wiper switch excellent $50 shipped
1] emergency switch excellent $50 shipped
DRIVETRAIN http://www.youtube.com/watch?v=Nzm_loMMj5s
http://www.914world.com/bbs2/index.php?showtopic=128301
1] O.E. steelie beauty ring $30 shipped
12] unobtainium "Dan Gurney/western rim" shouldered lug bolts $30 shipped
1] set of stub axles with couple $30 + shipping
1] set of complete used axels (ea. Has stub axle, axle, inner& outer joint good boots) $75 + shipping
1] set of used axels (minus 1 outer joint good boots) $30 + shipping
4] brand new in wrapping, c.v. joint gasket seals, hard to find when you need them, all 4 $25 shipped
1] set of 911 trans sport mounts $50 shipped
2] main e-brake brake cables very nice condition $ 75 shipped
1] O.E. walnut shift knob typical lens cracking but not too bad $30 shipped
ENGINE http://www.youtube.com/watch?v=HvRTiY1MfPU
http://www.914world.com/bbs2/index.php?showtopic=128302
1] Header w/ glass pack -after heat exchangers $75 + shipping
2] unused 96mm "rimco bored/honed" Mahle cylinders light fin damage $75 each shipped
1] complete engine set of 1.7rockers for swivel conversion (no swivels or machining) $80 shipped
4] 1.7 high compression raised dome "euro" pistons and wrist pins $95 shipped
4] 96mm flat top pistons, pins and rings w/ rings $85 shipped
1] set of 4 very nice 1.7 rods (reconditioned?) $55 shipped
4] 1.7 yellow injectors & hold downs $50 shipped
1] j-tube great shape $25 shipped
1] set of decent j-tube tin seals $20 shipped
1] 2 new cork, 1 rubber type valve cover gaskets, misc. engine gaskets, etc. . . $25
1] good used starter $65 shipped
1] huge bundle of misc. Nice o.e. braided hoses $25 shipped
1] ribbed/insulated heat tube $20 shipped
1] 2.0 throttle body w/ tps $ 95 shipped
1] 2.0 rubber throttle body to air cleaner sealing piece w/ clamp $25 shipped
1] NON sending unit oil cover and screen $20 shipped
1] oil cap $10 shipped
1] excellent rear trunk drain funnel $12 shipped
1] rear brake caliper $25 shipped
2] good used oil pumps $30 each shipped shipped or $50 both shipped
1] evaporative canister with securing hardware $30 shipped
2] used great shape o.e. oil pumps each $25 shipped
1] SET of 4 O.E. euro high(er) comp. pistons w/ rods $175 SHIPPED
1] SET of 4 1.7 rods $50 SHIPPED
1] SET of 4 flat top 96mm pistons $110 SHIPPED
2] MAHLE 96mm unused $50 each (OR $95 both) SHIPPED
1] distributor complete to drop in 02380100049 022906205B, has points, F.I. trigger contacts even the clamp. $125 shipped
1] NEW set of Napa Echlin points & condenser $30 SHIPPED
2] F.I. contact points used $50 (OR $95 both) SHIPPED
1] new plug wires (2/long 2/short plug boots 1.7 or 2.0?) + 4 brand new MSD
wires (36"), misc. new boots, separateters, end crimp pieces $75 SHIPPED
1] set of 4 green top 2.0 injectors. $175 SHIPPED
1] cold enrich injector (pass thru routing) $30 SHIPPED
1] cold enrich injector $30 SHIPPED
1] TPS used WITH n.o.s. box $35 SHIPPED
1] M.P.S. 74-76 2.0 #0280100043, adjusting cap removed $75 SHIPPED
1] M.P.S. 70-73 1.7 #0280100049 022 906 049, unmolested cap (can use 2.0 cap to calibrate this one for 2.0 thru 2056) $75 SHIPPED (buy both 2.0 and this one for $125 SHIPPED)
1] M.P.S. 75? 2.0 #0231172021 022906051E unmolested cap $55 SHIPPED
1] AAR valve solid with excellent wire and plug $65 SHIPPED
3] 2.0 plenum sensors $30 SHIPPED
INTERIOR http://www.youtube.com/watch?v=rWa8oHbSeEM
http://www.914world.com/bbs2/index.php?showtopic=128305
1] set of "butt breathing" fabric seat inserts, both w/ good sensors {worn material} great to temporary swap in for hot sweaty days or long drives $65 shipped
1] set of used crown vic power lock solenoids $30 shipped
1] H/D power lock solenoid new $25 shipped1] Custom steel/vinyl covered 6 gauge panel w/lights and rocker switch area and misc. parts . . . unfinished project. . . $35 shipped
1] 12 ft. of special twisted CHT wire (I'll measure soon) $25 shipped
1] used turn signal switch (no harness)$15 shipped
1] Custom vinyl covered 6 gauge console face panel, unfinished project. Set up for rocker switches and multiple lighting, comes with misc. add your gauge selection and finish $50 shipped
1] VDO oil temp. gauge $15 shipped
1] S/W 30 amp. Gauge $15 shipped
1] S/W oil temp. gauge $15 shipped
1] batch of misc. gauge brackets & lights $15 shipped
Or. . . ALL above gauges, brackets and panel $85 shipped
1] 12 FT. of special spiral CHT wire $10 shipped
1] 72 up dash vent $25 shipped
1] sun visor center mount bracket $10 shipped
EXTERIOR http://www.youtube.com/watch?v=uc2UeCO2t1U
http://www.914world.com/bbs2/index.php?showtopic=128306
1] fuel sending unit w/ extra ring & mounting hardware misc. $75 shipped
1] engine trunk lid complete w/ grill solid west coast part $75 + shipping
1] bumper dog bone $10 shipped
1] door handle GREAT chrome, damage to lock release fork (finger broke)repairable? $20 shipped
1] license plate bracket $15 shipped
- it's NOT ok to contact this poster with services or other commercial interests
