914fun
Jun 14 2011, 05:08 PM
I had a local mechanic install a new clutch, Pilot Bearing, and Rear Main seal. but now shortly after i see oil everywhere under the car. looking in the whole in the top of the trans I see lots of oil on the flywheel and can tell the oil is coming from where the trans and the motor meet. Could he have put the rear seal in wrong? Is that possible?
underthetire
Jun 14 2011, 05:11 PM
Yes, and if you don't use one of the "good" seals, you'll be doing it again. Don't ask how I know
914fun
Jun 14 2011, 05:39 PM
How could he have messed that up? Can it be put in Backwards? or any other way?
windforfun
Jun 14 2011, 05:49 PM
What a PITA. This is exactly the kind of BS that I HATE!!! You have my condolences.
914fun
Jun 14 2011, 05:56 PM
I feel bad for the shop he worked at because it was blown away by the tornado. So I wanted to talk to you all before I tried to find him or even if I should.
simonr
He pounded the seal in too hard. You need to have him fix it quick or you will foul the clutch. I just went through this . i was the one who learned the hard way about being too agreessive with tapping it in
Cap'n Krusty
Jun 14 2011, 06:09 PM
Motor oil? Gear oil? Did he change the flywheel o-ring?
The Cap'n
914fun
Jun 14 2011, 06:16 PM
He did not put it on the list of things he did. But I'm putting a lot of oil in it. Probably have not driven it 200 miles and have put in two quarts. So I have stopped driving it.
iamchappy
Jun 14 2011, 06:44 PM
I just put one in last weekend, i put mine in the freezer overnight oiled up the inner seal and tapped in right in with a 4" pvc shower drain....
IronHillRestorations
Jun 14 2011, 06:51 PM
That's a bummer. Unless it's REALLY bad, you may not need a new disc, but I'm betting a new main seal and flywheel O ring will be needed.
914fun
Jun 14 2011, 07:07 PM
Think your right. The clutch seems to still be working good so I hope it will be ok. Is there something I should clean it with when I get it apart? Maybe just dish soap and water.
simonr
Jun 14 2011, 07:33 PM
clean it with acetone nothing else.
