QUOTE(Cap'n Krusty @ Jun 15 2011, 06:45 PM)
Remember, it's 10mm x 1 TAPERED thread, NOT conventional 10x1 straight thread. It's virtually indistinguishable from 1/8 NPT. You could probably cut both with the same tap and never know the difference. The 10mm x 1 straight thread is used in more modern applications, and always with a copper washer. Typical VDO dual post senders for our application have tapered threads and should not be used with adapters having straight 10mm x 1 holes. I suggest a grease gun hose, because they're cheap and readily available. They normally withstand 1500-3000 PSI, so they're substantially overengineered for this use. As always, you'll have to ground the sending unit in order for it to work properly.
The Cap'n
grease gun hose available at any flaps
