QUOTE(matteyp @ Jun 15 2011, 05:01 PM)
Just trying to figure out how I can open it now.
Open the engine lid, push one of the plastic cups that hold the targa top latches inside the trunk, get a flashlight, add enough extensions to your ratchet to cover the distance from the engine compartment to the trunk lock, add a 10mm socket to your extensions and unbolt the lock that way.
This is MUCH easier if you push the second plastic cup into the trunk as well and have someone else shine the flashlight through that hole for you.
