Hi guys,
I have a spare 2.0L that I want to use in my car. The engine looks good except one of the heads that has some cracks. It was probably dropped on the floor by the PO.
Here are some pictures. The crack is in the valve chamber and don't extent to the compression chamber. However, the 2 leftmost push-rods tubes holes are cracked.
To fix it, will need to weld the cracks and rebore the push-rods tubes holes.
Do you think this is rebuildable or should I look for an other head?
