Mitch 914
Jun 18 2011, 10:50 AM
Now I am not getting any gas? Fuel pump working I took off fuel line and the gas is pumping? When I pull on the fuel linkages I do not see any squrting of the gas?Rann before it took it apart?? Carbs sat in my trunk for a week do you think fuel bowls stuck??? Help
McMark
Jun 18 2011, 03:29 PM
Did you let the fuel bowls fill up? It can take a minute or two to get enough fuel in the bowls, and then a few pumps on the linkage to get fuel through the system.
The needle valves could have stuck shut, you can pull the carb tops rather easily and check. And while you're in there double check your float heights and write down your jet sizes if you don't already have a note of them somewhere.
