QUOTE(simonr @ Jun 19 2011, 05:27 PM)
Green is on + . black and red on #12. Black on #15 thats the only way it will run I think that is backwards. It wont run the correct way
Terminal 12? Where is that ?
The 'black' wire - where does that go?
Try leaving it off - it's probably the tach (should have a violet tracer...)
Then - black and red to Terminal 15 (+) - first verify that this is your switched +12
And the points wire to Termina1 1 (-).
Are there other wires connected to the distributor? Where do they go...
The Kettering ignition system is dirt-simple, but it does have a few rules...
