newdeal2
Jun 14 2004, 04:57 PM
I purchased a set of Mahle pistons and requested flat tops. They sent me dished. I am keeping the engine stock [it's a 2.0 FI] and I figure I am only picking up about 3 hp with the flats so I may just put these in. I was told the dished also run cooler...any tuth to that?
Peter
Jake Raby
Jun 14 2004, 04:59 PM
How big is the dish (cc wise) have a pic?
seanery
Jun 14 2004, 05:08 PM
non-educated guess here:
Do the dished run cooler because the compression is lower?
Jake Raby
Jun 14 2004, 05:34 PM
There are different dished pistions.. Bus pistons have a 13-15cc dish. US Spec 914 pistons have a 7cc dish. Euro pistons have a 3cc dish, and some are totally flat.
LOWER CR DOES NOT RUN COOLER! The combinations of CR and camshaftare endless. Lower CR runs just as hot because it kills efficiency. Bus engines used lower CR mainly to get rid of cylinder pressures- a bus weighs near 5,000 pounds.
Part Pricer
Jun 14 2004, 05:35 PM
Peter,
I'm not sure who you purchased these from, but if you decide to keep them you should make sure that they compensate you correctly. There is a dealer cost differential of $39.38 per set. IMO, they should offer you at least $50 to keep them.
BTW, I wouldn't keep them. Insist that they send you what you paid for and have them pay shipping to return the wrong item they shipped.
Mark Henry
Jun 14 2004, 05:51 PM
The big dish are bus pistons, if you paid for euro's (flat tops) then that's what you should get. Also the shipping should be on their dime if you ordered the euro's.
newdeal2
Jun 14 2004, 06:26 PM
Well the owner will replace them with Flat Tops on his dime. If they don't run "cooler" ... I don't want to sacrifice compression.
Thanks guys
Jake Raby
Jun 14 2004, 07:16 PM
How can you prove they run cooler??
ALL the engines tuning will change with these, as the efficiency has been changed by about 20%.
Jun 14 2004, 07:18 PM
dude, 3 (or even 4) threads for one question ???
can't you keep it all together?
i'm getting all confuzzeled,
Andy
newdeal2
Jun 14 2004, 07:32 PM
Andy,
It's under control. Won't happen again
Pnambic
Jun 15 2004, 06:20 AM
Dang, I thought at first that this thread might be about the DETROIT PISTONS humiliating those left coast Lakers in the finals this year.
Go PISTONS!!!
newdeal2
Jun 15 2004, 11:32 AM
OK, West Coast Core is sending me a set of AA Forged Flat top pistons. He says there are good pistons but then I am not sure who to trust.
Any opinions?
Part Pricer
Jun 15 2004, 11:37 AM
AA? Others will chime in here, but I believe that those are the ones that are made in Japan and are of questionable quality.
Mueller
Jun 15 2004, 11:44 AM
for the money, the AA import parts are a decent deal(inspect them carefully)
not too sure they offer forged pistons or not, my euro 2.0 flat tops from them are cast
Go PISTONS!!!
Mark Henry
Jun 15 2004, 11:57 AM
Hmmmm.....
Sounds like someone that should be avoided. <_<
If you paid for Mahle's you should get Malhe's.
I'd most likely send it back and say forget it dOOd.
Part Pricer
Jun 15 2004, 12:12 PM
QUOTE(Mark Henry @ Jun 15 2004, 12:57 PM)
Hmmmm.....
That's really good advice.
I would send the seller a note stating something like:
While I don't believe you intentionally listed this auction item fraudulently, it was an incorrect and negligent listing under Ebay guidlines. Since I did not receive what you advertised, I am return shipping it to you and expect you to return my $xxx.xx total costs plus an additional $yy.yy for return shipping costs which I expect will be the same as the original. This would make a total of $(xxx.xx + yy.yy). On receipt of your payment, I will consider the auction transaction complete and will leave you a positive feedback indicating you quickly resolved a problem and stand by what you are selling on ebay. As I notice most of your transactions are selling, this should be of help to you in all future transactions. Please reply.
Mark Henry
Jun 15 2004, 02:29 PM
Can we have the link to the ebay auction you won?
newdeal2
Jun 15 2004, 04:12 PM
Here's the auction link. The pistons he sent were Mahles...they were in the original "kit" box. As you will see in the description he says add $70.00 for the flat tops. Somehow he missed it and sent the dished [bus] pistons. The owner has been very cooperative and also refunded the extra cost to ship them back. He is sending me AA flat tops and that's the only question at this point...will they be as good or equal to the Mahles.
newdeal2
Jun 15 2004, 04:14 PM
Mark Henry
Jun 15 2004, 04:51 PM
Found it before you fixed it...
BRAND NEW TYPE IV/PORSCHE piston and cylinders in the box ready to go set of 4 piston and cylinders 94mm,MANUFACTURE IS MAHLE. new piston, cylinders, rings, keepers, wrist pins. supplies are limited so purchase while at this low price. check my other auctions for: A complete engine gasket set $39.95 3)Pair rebuilt TYPE IV HEADS $359.95 exc. we also have ever thing to rebuild your complete motor in stock for immidiate delivery. ALso these are dished pistons if you would like flat topped add $70.00 to final price. thanks for looking, bidding and purchasing in advance. WEST COAST CORE 661-726-9915
If you paid $229.95 for your pistons, then yes, you bought bus pistons.
If you added the $70. you should get
Mahle flat tops.
The AA's will work, just not as as good quality wise. Look for defects and I believe Jake said they're heavier. Get them balanced.
newdeal2
Jun 16 2004, 08:05 AM
Hmmm. balance them...sounds expensive. What's the advantage?
Mark Henry
Jun 16 2004, 08:18 AM
If they’re way off it’s not good.
Try Fisher Buggies in Tampa, or ask Sundance Bugs in Tarpon Springs to help you out.
It should be under $50.
Or if you have a dope smoking buddy with scales….
Jake Raby
Jun 16 2004, 08:26 AM
BALANCE EVERYTHING!
Engines are reciprocating and rotating all the time. Out of balance conditions can rip the engine apart, make everything vibrate loose, wear bearings and COST HP!
I spent 40K bucks on my balancer- because balancing is a MUST!
You should see just how far out assemblies can be, and some pistons (Mahle's) have been out 23 grams in one set!
newdeal2
Jun 16 2004, 10:21 AM
OK...sounds like a must. So what do they do to balance them? Remove/add material on the inside?
newdeal2
Jun 16 2004, 10:30 AM
Will I need to do anything else to the cylinder/pistons [they are a kit] before installing?
Jake Raby
Jun 16 2004, 12:11 PM
Material is removed from the pistons, for balance purposes.
TROJANMAN
Jun 23 2004, 10:02 AM
i just found this thread on a search, because i am rebuilding my engine. i too contacted West Coast. the guy told me that the mahle's were unavailable in the flat tops, then tried to push the AA pistons on me. he said it was an NPR company, or something like that, and that is what people were using at the local track. any thoughts? he did say they were forged and made in Japan.
Part Pricer
Jun 23 2004, 10:11 AM
QUOTE(glstrojan @ Jun 23 2004, 11:02 AM)
Mahle Euro P&Cs are available. There are plenty in the distribution channel.
TROJANMAN
Jun 23 2004, 10:14 AM
QUOTE(Paul Heery @ Jun 23 2004, 08:11 AM)
any recommended place to make the purchase? what's a good price?
Part Pricer
Jun 23 2004, 11:38 AM
The price that you will pay depends on how much you want to work.
The lowest price on the net is from
Boozak. Their price for Mahle 94mm non-dished P&Cs is $467.82 shipping included. Search on part number and enter A2042-35386.
If you want to work a little bit, contact
drivewire. They have a policy where they will beat other people's prices by 5%. Point them to product # A2042-35386 on the Boozak site and they should give them to you for $444.43 shipping included. BTW, the drivewire catalog has them for $480.02.
It really doesn't matter who you order them from. They'll be drop-shipped from the same warehouse.
TROJANMAN
Jun 23 2004, 12:36 PM
thanks
seanery
Jun 23 2004, 12:37 PM
HIJACK ALERT
I've got a question regarding size. If I've got 94mm Euro Pistons and switch to 96mm flat pistons will there be a noticeable difference? Other mods already done are a webcam 494, dual IDF 40s, SSIs...
thanks.
/HIJACK
TROJANMAN
Jun 23 2004, 04:53 PM
FYI _this place was the cheapest i found for p&c prices.
parts
Mueller
Jun 23 2004, 05:02 PM
FYI _this place was the cheapest i found for p&c prices. parts
a few problems with that find:
no mention what kind of pistons/cylinder for the smaller size, and the shipping from Germany could offset any savings.....for cheap import P/C's, AA Imports is still the cheapest (not automobile atlanta)
