914coop
Jun 19 2011, 07:38 PM
Need more help.
I have a 76 2.0 d-jet.
Engine runs fine when first started, after it warns up it starts surging (Jerking) around 3500 rpm's. What I have done so far.
- Adjusted valves
- Replace Fuel Pressure Regulator
- Disconnected TPS, Problem still exists when disconnected.
Idles nice at 900 rpm's
Any ideas on what else to check?
Thanks Irv.
JeffBowlsby
Jun 19 2011, 08:54 PM
Is that jerking at 3500 rpm while then car is stationery or while going down the road. If while driving, its probably a worn out TPS.
76-914
Jun 19 2011, 09:15 PM
And can you pass thru 3500rpm; if so does it smooth out?
914coop
Jun 19 2011, 10:21 PM
It does not seem to smooth out, Although I have not really spent much time pushing it past the point of surging. I will give it a good try tomorrow.
underthetire
Jun 20 2011, 08:44 AM
Check the mechanical advance on the distributor.
