QUOTE(r_towle @ Jun 22 2011, 11:54 AM)
on DD diagram the "cold start valve" is the little electrical flapper inside the air filter assembly, not the "cold start injector"
Not all throttle bodies have two vacuum ports for the distributors...the factory sent these cars out with a short hose on the distributor left open to the atmosphere....so no worries there.
The large line from the oil filler tower should be attached to the intake plenum, not the throttle body and not in front of the throttle body. If its sucking oil, you need a new PCV valve in the oil filler tower.
Rich
You said: "On DD diagram the "cold start valve" is the little electrical flapper inside the air filter assembly, not the "cold start injector". That's wrong. In the drawing, the CSV is clearly marked underneath the air cleaner housing, and that's where the 12mm vacuum hose from the AAR goes. There is no "little electrical flapper inside the air filter assembly, not the "cold start injector". Nothing but air filter in there. The CSV sits on a plastic spacer/hose fitting on the side of the intake plenum.
The Cap'n
