To help you know exactly what you're paying, MOST every item I covered shipping cost, a few heavy/bulky items I did leave open to actual cost. These are my personal stash for my 73 I just sold.
EXTERIOR [url="http://www.youtube.com/watch?v=uc2UeCO2t1U"]http://www.youtube.com/watch?v=uc2UeCO2t1U[/url]
1] targa top w/ non opening sun roof. Great topless compromise for cool sunny days [b][color="#FF0000"]SOLD[/color][/b]
1] targa rear latch set great shape with hardware[b][color="#FF0000"]SOLD[/color][/b]
1] very nice "Porsche" reflective tail light section [b][color="#FF0000"]SOLD[/color][/b]
1] electric trunk release solenoid used with or w/out above reflector [b][color="#FF0000"]SOLD[/color][/b]
1] unused/brand new, trunk gas strut kit, will add a set of used bolt on struts if wanted $55 shipped
1] fuel sending unit w/ extra ring & mounting hardware misc. $75 shipped
1] engine trunk lid complete w/ grill solid west coast part $75 + shipping
1] bumper dog bone $10 shipped
1] door handle GREAT chrome, damage to lock release fork (finger broke)repairable? $20 shipped One of the two little "fingers" that move the plastic lock peice (that always seem to need to be placed) got broke during an attempt to change out the plastic piece. I'm hoping that someone has more patience than myself to salvage this otherwise excellent part.
1] license plate bracket $15 shipped
1] excellent rear trunk drain funnel $12 shipped
1] FREEEEE misc. exterior aluminum body trim FREEEEEE. . .. Pickup only too bulky to ship
LIGHTING & ELECTRICAL [url="http://www.youtube.com/watch?v=9kBQ0qkE4tE"]http://www.youtube.com/watch?v=9kBQ0qkE4tE[/url]
1] set of very nice hella O.E. U.S. spec. tail light lens w/buckets and special attaching nuts [b][color="#FF0000"]SOLD[/color][/b]
1] front euro turn signal light conversion kit (instructions, bulb sockets, dividers, etc. . .) everything needed to convert to euro but the lens [b][color="#FF0000"]SOLD[/color][/b]
1] front lens w/ (2) seals [b][color="#FF0000"]SOLD[/color][/b]
1] set of chromed driving light grills, fins 100%, chrome shot [b][color="#FF0000"]SOLD[/color][/b]
1] side marker light base $15 shipped
1] 1972 d-jet relay board $30 shipped
1] fuel sending unit w/ring & misc. attaching hardware $75 shipped
1] cut alt harness (good 4 alt plug body or pigtail) $15 shipped
1] wiper switch excellent $50 shipped
1] emergency switch excellent $50 shipped
1] 72 turn signal switch $30 shipped
INTERIOR [url="http://www.youtube.com/watch?v=rWa8oHbSeEM"]http://www.youtube.com/watch?v=rWa8oHbSeEM[/url]
1] set of "butt breathing" fabric seat inserts, both w/ good sensors {worn material} great to temporary swap in for hot sweaty days or long drives $65 shipped
1] set of used crown vic power lock solenoids $30 shipped shipped
1] H/D power lock solenoid new $25 shipped1] Custom steel/vinyl covered 6 gauge panel w/lights and rocker switch area and misc. parts . . . unfinished project. . . $35 shipped shipped
1] 12 ft. of special twisted CHT wire (I'll measure soon) $25 shipped shipped
1] used turn signal switch (no harness)$15 shipped shipped
1] Custom vinyl covered 6 gauge console face panel, unfinished project. Set up for rocker switches and multiple lighting, comes with misc. add your gauge selection and finish $50 shipped
1] VDO oil temp. gauge $15 shipped
1] S/W 30 amp. Gauge $15 shipped
1] S/W oil temp. gauge $15 shipped
1] S/W vacuum gauge $15 shipped [b][color="#FF0000"]SOLD[/color][/b]
1] batch of misc. gauge brackets & lights $15 shipped
Or. . . ALL above gauges, brackets and panel $85 shipped
1] 12 FT. of special spiral CHT wire $10 shipped
1] 72 up dash vent $25 shipped
1] O.E. walnut shift knob typical lens cracking but not too bad [b][color="#FF0000"]SOLD[/color][/b]
1] sun visor center mount bracket $10 shipped
ENGINE [url="http://www.youtube.com/watch?v=HvRTiY1MfPU"]http://www.youtube.com/watch?v=HvRTiY1MfPU[/url]
1] Header w/ glass pack -after heat exchangers $75 + shipping
2] unused 96mm "rimco bored/honed" Mahle cylinders light fin damage [b][color="#CC0000"]SOLD[/color][/b]
1] complete engine set of 1.7rockers for swivel conversion (no swivels or machining) $80 shipped
4] 1.7 high compression raised dome "euro" pistons and wrist pins $95 shipped
4] 96mm flat top pistons, pins and rings w/ rings $85 shipped
1] set of 4 very nice 1.7 rods (reconditioned?) $55 shipped
4] 1.7 yellow injectors & hold downs[b][color="#CC0000"]SOLD[/color][/b]
1] j-tube great shape $25 shipped
1] set of decent j-tube tin seals $20 shipped
1] 2 new cork, 1 rubber type valve cover gaskets, misc. engine gaskets, etc. . . [b][color="#CC0000"]SOLD[/color][/b]
1] good used starter $65 shipped
1] huge bundle of misc. Nice o.e. braided hoses $25 shipped
1] ribbed/insulated heat tube $20 shipped
1] 2.0 throttle body w/ tps[b][color="#CC0000"]SOLD[/color][/b]
1] 2.0 rubber throttle body to air cleaner sealing piece w/ clamp [b][color="#CC0000"]SOLD[/color][/b]
1] NON sending unit oil cover and screen $20 shipped
1] oil cap $10 shipped
1] rear brake caliper $25 shipped SOLD
2] good used oil pumps $30 each shipped shipped or $50 both shipped
1] evaporative canister with securing hardware $30 shipped
2] used great shape o.e. oil pumps each $25 shipped
DRIVETRAIN [url="http://www.youtube.com/watch?v=Nzm_loMMj5s"]http://www.youtube.com/watch?v=Nzm_loMMj5s[/url]
1] O.E. steelie beauty ring $30 shipped
12] unobtainium "Dan Gurney/western rim" shouldered lug bolts[b][color="#CC0000"]SOLD[/color][/b]
1] set of stub axles with couple $30 + shipping
1] set of complete used axels (ea. Has stub axle, axle, inner& outer joint good boots) $75 + shipping
1] set of used axels (minus 1 outer joint good boots) $30 + shipping
4] brand new in wrapping, c.v. joint gasket seals, hard to find when you need them, all 4 $25 shipped
1] set of 911 trans sport mounts $50 shipped
2] main e-brake brake cables very nice condition $ 75 shipped
1] O.E. walnut shift knob typical lens cracking but not too bad[b][color="#CC0000"]SOLD[/color][/b]
F/S F.I. trigger points new points/cond, spk wires
1] NEW set of Napa Echlin points & condensor $30 SHIPPED
2] F.I. trigger points used $50 (OR $95 both) SHIPPED
1] new plug wires (2/long 2/short plug boots 1.7 or 2.0?) + 4 brand new MSD
wires (36"), misc. new boots, separateters, end crimp pieces EVERYTHING! $75 SHIPPED
***F/S 1.7 euro pistons, rods, 96 P&C's
1] SET of 4 O.E. euro high(er) comp. pistons w/ rods $175 SHIPPED
1] SET of 4 1.7 rods $50 SHIPPED
1] SET of 4 flat top 96mm pistons $110 SHIPPED
2] MAHLE 96mm unused [b][color="#FF0000"]SOLD[/color][/b]
***F/S misc. M.P.S.'s & sensors
1] M.P.S. 74-76 2.0 #0280100043, adjusting cap removed[b][color="#CC0000"]SOLD[/color][/b]
1] M.P.S. 70-73 1.7 #0280100049 022 906 049, unmolested cap (can use 2.0 cap to calibrate this one for 2.0 thru 2056) $75 SHIPPED (buy both 2.0 and this one for $125 SHIPPED)
1] M.P.S. 75? 2.0 #0231172021 022906051E unmolested cap, W/ mounting bracket $55 SHIPPED
3] 2.0 plenum sensors $30 SHIPPED
***F/S set of 4 green top 2.0 injecters, coldstart
1] set of 4 green top 2.0 injectors. $175 SHIPPED
1] cold enrich injector (pass thru routing) $30 SHIPPED
1] cold enrich injector $30 SHIPPED
- it's NOT ok to contact this poster with services or other commercial interests
