I am listing this for a good friend here in Austin. I will be happy to provide contact info for anyone interested in a purchase.
Complete 3.2 System. Perfect for an 914 swap. Comes with EVERYTHING related to the motor except for fuel delivery system (pump, lines, etc) There is no six mount or oil system for a 914-6. This is just the motor and electronics.
The motor was just pulled from an 86 Cab that was wrecked up front. Tub was twisted and good for scrap. The underside of the motor is dry and the car does not leave any leaks on the driveway. The exhaust is in good condition and complete with cat. The motor has 96k on it and was a recreational driver for the PO.
The compression numbers are as follows:
Cyl 1- 170
Cyl 2 -170
Cyl 3 - 185
Cyl 4 - 180
Cyl 5 - 175
Cyl 6 - 190
The motor runs well and purred at idle. There is no hesitation on throttle response.
Motor is complete from exhaust to intake. Includes all wiring, DME, baro cell, engine wiring panel, DME, coil and matching tach. Not shown in the attached pic, but included is the stock air box. It was removed to clear the rear of the car when we pulled the drivetrain.
Asking $4800.00 obo plus shipping. The motor is located in the Austin,TX area. If you are converting an earlier car to an EFI 3.2L this is the way to go.
