QUOTE(Tom_T @ Jun 30 2011, 12:18 AM)
Phillip,
AA sells a repro fuel grade sticker for a few bucks.
The VIN stamping on the wheel housing top was taped off & left raw metal at the factory. Later DAPO repaints cover them if it's too much trouble to stick tape, or don't know to do so. I use a swipe of WD40 to keep it from rusting over. Clear coat enamel will do the same I suppose.
FYI - Acetone & a soft touch with a soft rag & Q-tips is the best way to lift paint off of the stickers, plates & labels. Let it set after a first swipe of acetone with a Q-tip, let it bubble up some & then work gently to get the paint but not the label/sticker. I was able to uncover my original factory VIN sticker on the L-R door jamb from 4 oversprays that way, with very little damage to the original sticker.
Thanks Tom,
I just flat out was not aware it was there, I was just skimming the area and nicked it, after I noticed it I did remove the paint with some thinner.
Actually I was able to lift my Vin sticker off the door jamb by heating it up and slowly pulling it up. I plan on regluing it back when it is painted.
