914itis
Jun 30 2011, 11:22 AM
I am new at doing body work. My question is: do you wet sand before the initial primer?
914.SBC
Jun 30 2011, 01:08 PM
I am no paint expert but I have done two cars and never wet sanded. I never even thought to do that. Wet sand after primer before paint and color sand after paint then clear coat.
914itis
Jun 30 2011, 01:57 PM
QUOTE(914.SBC @ Jun 30 2011, 03:08 PM)
Thanks for the info.good enough.
Andyrew
Jun 30 2011, 05:03 PM
Primer Epoxy? No.
Sand down with 80 grit, sand (if possible) to 180+ prior to spraying primer epoxy (an etching primer used to get a good adhesion base layer to start bodywork on.
Dont put water on the car until you are wet sanding the paint. (Unless your sanding primer sealer down to say 600 for a metalic color)
scotty b
Jun 30 2011, 05:21 PM
Dry sand until the final coat or two of primer/sealer depending on how nice you want the job to be. Wet sand the final coat of primer to 600. You can get away with 400 especially on a solid color, or on single stage paint, but 600 is best. When you go to wet sand the clear or final coat of single stage ( only on soild colors ) start with nothing harsher than 1500 if this is your first time.
