OK here's a place to get all your hardware cheap. . . McMaster Carr. . .
I bought the 1/8th x 5/16 hex thread cutting 'speed nuts. . . box of 100 was about 6 bucks. . they also have yellow zinc metric nuts, and the serrated little lock washers close to Porsche pattern. . . For 100 bucks you can get all the metric fasteners you'll ever need and their shipping is reasonable. .
http://www.mcmaster.com1 90533A132 1 Pack Zinc-plated Steel Flange Speed Nut, 1/8" Size, 17/32" Flange Diameter
2 92497A450 1 Pack Metric Zinc-yellow Pltd Class 10 Stl Hex Nut, M10 Size, 1.5mm Pitch, 17mm Width, 8mm Height
3 92497A500 1 Pack Metric Zinc-yellow Pltd Class 10 Stl Hex Nut, M12 Size, 1.75mm Pitch, 19mm Width, 10mm Height
4 94645A220 1 Pack Zinc-plated Steel Nylon-insert Hex Locknut, Class 10, M10 Sz, 1.5mm Pitch, 17mm Width, 10mm H
5 93501A033 1 Pack Black Finish Steel Serrated Belleville Washer,
