Yep cool. I'm restoring a 67 camper for family fun.
Rust can attack them just like 914's but they won't snap in half. Same layout as a 911. You check the floor, rockers and front for rust. They have a beetle engine, total baby brother to the 4 cyl. 914 engine, easy to work on. Trans is a swing axel with 1.1:1 reduction boxes (if stock) adds tourque and rpm's. Check trans for popping out of gear, including reverse. Will leak oil in exact same spots as a teen. 3/4 ton load rating and it will tow a trailer good. Anything over 65mph and the engine gets buzzy and hot. Heat sucks, some people block off and heat only the cab in the winter. Restoration of a crusty one would cost almost as much as a teen, same pitfalls.
Overall if you can do a good PPI on a 914, the bus should be no problem. If you treat it right it will go and last forever.
If you have more ? ask or you can email me.
Sorry, I don't agree with Ferg on the driving comfort bit, I'd much rather have a splitty. He must of drove a dog.
