I'm selling off my remaining 914 parts that you just may never find when you need them! Some in the unobtainium catagory. They are between $10 & $50. I pay the shipping! Usually priority.
I do ask that you buy at least $50 worth as my good wife does alot of the shipping and it is prohibitive otherwise.
when i get payment I'll ship. Iwill be gone from July 6th til the 13th. Please post a response to let others know what parts you commit too. 1st come 1st servered. Let me know any questions you may have.
NOTE: If you'd like to pay with pay pal please add 4.4%.
My Pay Pal is: ebayerrr@yahoo.com
Thanks for looking
ENGINE
1] set of used trans mounts w/ extra mounting hardware $30 SHIPPED
4] bosch super spark plugs W7CCO,lightly used, shows no wear, some carbon blacking $10 SHIPPED
1] nice 99% rust free oil cover plate w/ unique nut & washer $15 SHIPPED
1] speedometer gear drive load/rattle spring (you know the one that’s ALWAYS missing!) $15 SHIPPED
1] Very nice Oil sump screen & new o-ring $15 SHIPPED
1] 4 engine case bolts & 1 cyl/head stud $15 SHIPPED
1] set of engine lid hinges, nice $25 SHIPPED
1] main oil pressure piston 1] engine case cam plug $10 SHIPPED
4] O.E.M. engine bearing pins $10 SHIPPED
1] metal 2 nipple breather that goes by the oil fill $10 SHIPPED
1] plastic nipple that goes on a 2.0 intake runner somewhere as I recall
$10 SHIPPED
1] inside fan housing aluminum flap $7 SHIPPED
1] O.E.M. timing cover plastic screw in cap $15 SHIPPED
1] O.E.M. rubber/plastic alt tin hole cover $10 SHIPPED
1] Oil sending unit? See box of goodies pic. $10 SHIPPED
1] a couple barrel nuts for heat exchange & throttle cable $10 SHIPPED
2] stub axle nuts $10 SHIPPED
1] 1.7 intake rubber tube. Very nice flexible condition $50 SHIPPED
BODY & SUSPENTION
1] front hood latch w/ O.E.M. bolts and 4 washers $50 SHIPPED
1] engine hood latch $40 SHIPPED
1] trunk key latch w/ mounting hardware, no key $40 SHIPPED
1] set of very nice targa storage front clips $30 SHIPPED
1] set of Original paint head light cover body metal $25 SHIPPED
1] hook and spring that commonly breaks on rear targa latch $15 SHIPPED
1] O.E.M. underhood min/max pressure decal $10 SHIPPED
3] odd shaped strut top washers $ 10 SHIPPED
2] top of strut stud rubber & washers $10 SHIPPED
1] nice single hood hinge $10 SHIPPED
1] set of special shouldered hinge pivot bolts w/ washers $10 SHIPPED
INTERIOR
1] set of very nice door stiker plates with all attaching hardware
$50 SHIPPED
1] set of chrome inside door handles complete & ready 4 clean up
$30 SHIPPED
3] maybe 1 more, door light switches $15 SHIPPED
1] several special “inner door frame mounted nuts” w/ allen for panel attachment $10 SHIPPED
1] set of interior coat hanger hooks (were these the 70’s equivalent to cup holders?) $10 SHIPPED
1] hand full of “double square” c.v. bolts and long rounded “underneath washers” $10 SHIPPED
LIGHTING & ELECTRICAL
1] rear euro lens “made in Germany Hella”. I left dirty to show real condition. No major scratches or imperfections. All studs good. factory glue let go between yellow/red lens… not uncommon & EZ fix. Will clean & polish very nicely. It has “L” but check the picture for L or R $50 SHIPPED
Click to view attachmentClick to view attachment
1] set of very nice plastic head light motor covers, I could find no damage $30 SHIPPED
1] O.E.M. fog light bulb $25 SHIPPED
1] very clean O.E.M. body to ground strap $15 SHIPPED
1] O.E.M. tall relay $15 SHIPPED
1] O.E.M. wide relay $15 SHIPPED
10] O.E.M. small round relays $12 each SHIPPED
2] small round relays $10 each SHIPPED
1] side marker light base & gasket NOT concourse but cheap & useable
$10 SHIPPED
