Mueller
Apr 21 2003, 05:39 PM
For my /4 2.0, I don't have to split the case correct?
Should I just be able to remove each stud as I replace them with the new ones?
the new ARP crankcase and head studs are a work of art
(dare I say studly, LOL)
Mike
Brad Roberts
Apr 21 2003, 05:42 PM
Just remove them. No need to split the case.
You shouldnt have daired... now I will have to eat dinner...
Bad joke Mikey.
B
Mark Henry
Apr 21 2003, 08:01 PM
I hate to say this, BUT doesn't the case through bolts have those little plastic vibration damper ribbed looking thingy’s snapped over the studs, that sit in the middle of the case along the main bearing saddles.
Won't these bust apart? I can't even get them off in one piece with the engine apart.
Doesn't the case through holes double as oil passages?
Brad Roberts
Apr 21 2003, 08:05 PM
I didnt read all of it. I saw ARP and *THOUGHT* he bought the head studs and was asking about them.
Split the case to install the thru bolts.
B
Dave Cawdrey
Apr 21 2003, 08:09 PM
I wanna check those studs out. Got a pic or web site?
Mark Henry
Apr 21 2003, 08:15 PM
Yep, Brad you would have had Mike swearing up a storm when he couldn't pull those studs out!
So Mike now you have bust your case open, whats the tally up to now?
Brad Roberts
Apr 21 2003, 08:18 PM
I didnt tell him to buy the case thru bolts.. dont run them.
Your not running some monster stroker engine here where you should have dowel pinned the mains. We are worried about boost seeping out from the heads..
B
Mueller
Apr 21 2003, 08:25 PM
I am not going to split the case.......
So I guess these studs will be used elsewhere, not on this motor...
Brad Roberts
Apr 21 2003, 08:31 PM
Are they truelly studs ?? with threads on both ends for the case halves ??
I will need a set for a race 2.3 that needs gone thru. I'll buy the heads studs when I have money...
B
Dave Cawdrey
Apr 21 2003, 09:38 PM
Where can I see them?? I'm trying to be polite...
Brad Roberts
Apr 21 2003, 09:42 PM
Here you go..
Hey.. how come you slacked off in the pot references ?? LOL
http://www.raceware-fasteners.com/prod01.htmB
Mueller
Apr 21 2003, 10:27 PM
yep, threaded on both ends....
Dave....the camera and the studs are at two different locations...I'll try and shoot a few pics tommorow
Dave Cawdrey
Apr 21 2003, 11:12 PM
QUOTE(Brad Roberts @ Apr 21 2003, 07:42 PM)
Here you go..
B
Trying to lay off it somewhat
Talkin about it makes me think about it, more.
Got some motor build plans on the brain. Jus need my crank. 78 stroke .20/chev. journals... Anyone
