1974 Porsche 2.0L fuel injected manufactured 8/73. Color is Bahia Red L30E or Porsche color G2 with black leatherette interior. Original Fuchs alloy wheels Appearance Group which consists of bumperettes, Fuchs forged alloy wheels, center console with clock, volt and temp, fog lights and chrome bumpers. Title is clear and correct. Car has new Minnesota Collector plates.
Have Porsche Certificate of Authenticity (COA) which confirms the engine number and VIN match.
VIN #4742901009
Engine #006765
Transmission #HA18 08 3
Chassis #3449569
Mileage 125,132
New parts acquired and or installed:
• 4 installed/balance 195/55R-15 Michelin Pilot Exalto PE2.
• New relay board/cover and relays (installed)
• New fuses and fuse box cover.
• New starter
• Bosch blue ignition coil-new
• Air filter (installed)-new
• Speedometer cable-new
• Spark plugs-new
• Spark plug wires-new
• Distributor cap & rotor-new
• Ignition points-new
• Accelerator cable & return spring-new
• Clutch cable-new
• Alloy center caps (new) (installed)
• Dome light and light bulb (installed)-new
• Vacuum line kit-new
• Push rod tub seal kit-new
• Valve cover seals-new
• Oil cooler seals-new
• Oil filler seal-new
• 8 piece shifter bushing kit-new
• OEM ignition switch (installed)-new
• New old stock (NOS) muffler & seals
• Certificate of Authenticity
Engine is not running.
Located in Minneapolis, MN. $2,800.00 OBO.
