ne14914
Apr 21 2003, 08:59 PM
UHG!!!
I installed a new steering wheel and now the horn is stuck. I have taken it a part and put it back together, but i can get it to stop.
What did I miss?
seanery
Apr 21 2003, 09:11 PM
you shorted the ground(or the hot) of the horn button most likely.
I know, duh, real clever diagnosis.
Look for a pinched wire or torn insulation somewhere.
If you take the wheel of does it still do it?
ne14914
Apr 21 2003, 10:07 PM
No ity doesnt - however as soon as i put the adapter on - it does it again
Brad Roberts
Apr 21 2003, 10:10 PM
Your controlling the ground to the horn relay with that brown wire.
Make sure that the adapter doesnt touch anything it shouldnt.
Do you have a camera ?? I need to see what wheel and what horn button you have along with a column shot.
B
ne14914
Apr 22 2003, 12:07 AM
Here you go -
The horn blows when I put the adapter on - I havent even hooked up the horn button yet.
Brad Roberts
Apr 22 2003, 12:15 AM
Horn button. I need to see the back of it.
Some of them have a spring that holds it into the wheel.
You have to really protect that single wire after you plug it onto the horn button..the wire can hit the steel clip after you push it into the center of the wheel.
B
ne14914
Apr 22 2003, 12:36 AM
I havent even connected the horn button yet and it still goes off.
If i take the wheel off the adapter, and just connect the adapter - the horn will blow - without the wheel or horn button connected.
Brad Roberts
Apr 22 2003, 12:48 AM
Did you put the plate on the back of the steering wheel that has the wire attached to it ??
B
ne14914
Apr 22 2003, 12:59 AM
yes its there -
Its like as soon as the adapter touches the back of the steering column the horn goes off
kdfoust
Apr 22 2003, 10:10 AM
First, see my response in
this thread on Pelican.
If that doesn't make sense check this out:
djm914-6
Apr 22 2003, 10:18 AM
Looks like kdfoust found the problem I had when installing a MOMO onto my friends '73. I just bent the little contacts (circled above) in toward the center a little bit and the problem was solved.
Good luck,
