QUOTE(76-914 @ Jul 10 2011, 07:08 AM)
Btw, I got 3 survivors from those Butterfly seedlings. How long before they top out?
They should be at least a foot tall by now and flower buds forming. I transplant mine into 5 gallon containers or plant directly into the ground; they have a substancial root system by the time they are 1 foot tall.
The reversing relays are the key; I had a 10 gauge wire running from the battery to a power amp in the front trunck already; so, I ended up with a plenty of power for the window motors. I would recommend making the window-lifting mechanism as free from friction as possible first, now that I've been through the install
Here's a pic of the reversing relay set up; it was pretty easy to do and they mounted easily in the door recess.
