QUOTE(Dr Evil @ Jul 13 2011, 06:57 PM)
Honestly, if it is rebuilt, it should shift pretty well with only a little bit of room for improvement.
Which bushings did you replace? How is your stick shifter? There are bushings in it that wear and are seldom replaced.
I think that there are still things needing addressing. I have owned a few of these, worked on several, and they always shift damn good when I am done with them. I hope there is an easy fix.
I have had many 914's since 1978 and yes I replaced all of the bushings, however maybe the shift rod wore down over the last 25 years. I tried several new firewall bushings and it was still sloppy. At that point Thomas recommended the spherical firewall bearing. He shaved down the shift rod to fit. It made a world of difference. The Rennshift was just icing on the cake.
A better condition shift rod that fit the stock firewall bushing better probably would of also made a big difference. I agree there shouldn't be any slop in that bushing.
