No, I don't want to recreate a lot of the questions and answers that I've already seen in the existing collection of oil cooler threads, rather I'd like your opinion on how I should go about setting mine up with my current config.
Here's the scoop. I'm running a 3.2 with the stock engine oil cooler and a small external oil cooler tucked up under my right rear fenders controlled by a Mocal thermostat. FWIW, this config is fine for street use, and I rarely see the temps going above 210 on the hottest days unless I really push the car. However, I may start doing some track stuff again next season and will obviously need a better cooling approach.
I want to run a front cooler in the traditional spot and will probably make my own duct work similar to a stock GT setup to exit out the floor of the trunk. I haven't decided on the cooler, but let's assume something in the RX-7 style/range. Here's the real root of my dilemma, I want to retain my front bodywork without cutting massive holes or needing to buy a new GT style front bumper/valence setup. If I remove the body plugs in front of the cooler and add small electric fans to the cooler, do you think that will be enough to keep the engine temps in range? Anyone with similar experience good or bad?
Thanks,
Dion
