I keep thinking I need to buy a replacement due to grinding in 2nd & sometimes 3rd. Then there's times like today when it doesn't grind between shifts. (I keep hearing Jim Chambers saying "change yer bushings")!
If I shift fast they'll grind. If I shift at 4000+ 2nd will grind going in. Slow normal shifting will make it either smooth or grind, I never know which. A rebuild would be more expensive than the tranny I thinkin on getting.
Need thoughts.... thanks,
..........b
