914fun
Jul 12 2011, 08:03 PM
Just wanted to know about how long it should take to put in a new rear main seal so I can tell if the shop is putting the screws to me.
Cap'n Krusty
Jul 12 2011, 08:09 PM
Not more than 3 hours, given the usual stripped axle bolts and such. Be sure they change the flywheel o-ring, too, and replace the lock plate for the flywheel bolts. A really experienced wrench should be able to shave an hour off that without cutting corners or sacrificing quality. Parts should run about 35 bucks, 40 at the outside.
The Cap'n
underthetire
I can do it in 4 hours, but I'm not a shop. Probably less if I really felt like busting my ass. Keep in mind some cars just won't come apart easy if they are rusty.
jonferns
Jul 12 2011, 08:13 PM
I'll be doing this job this week as well.
914fun
Jul 12 2011, 08:17 PM
QUOTE(Cap'n Krusty @ Jul 12 2011, 09:09 PM)
The Cap'n
Thanks, I just had a clutch put in about 300 mile ago and they put in all new parts. So do you think I should replace the Flywheel o-ring too or should it be ok since its not old? I have the new seal but will get the o-ring if you think I should.
underthetire
Jul 12 2011, 10:40 PM
I'd do it. It's a 50 cent part. Why take a chance to have to tear it apart again. And there are good main seals and bad main seals. Learned that one the hard way.
brant
Jul 12 2011, 10:50 PM
might I also recommend changing the transmission out put seal if you (or someone for you) is already in there.
I find them leaking as often as rear mains and now like to just change them when ever I'm in there.
its probably another 10$ in parts and 15 minutes while your already in there.
brant
76-914
Jul 13 2011, 08:09 AM
and listen to the Cap't re: the flywheel lock plate. acts as a lock washer for those flywheel bolts.
Cap'n Krusty
Jul 13 2011, 08:20 AM
QUOTE(brant @ Jul 12 2011, 09:50 PM)
brant
You mean the transmission "input" seal, right?
The Cap'n
barada
Jul 13 2011, 10:46 AM
I am doing this as well this week. Are you going to provide photo's?
Phillip
brant
Jul 13 2011, 12:41 PM
QUOTE(Cap'n Krusty @ Jul 13 2011, 08:20 AM)
brant
The Cap'n
Aye! that I do
thanks for the correction
my brain often knows what I'm thinking, but my mouth (and fingers) sometimes struggle to get that thought across.
brant
914fun
Jul 15 2011, 11:06 AM
Thanks Guys, I ordered the rest of the parts today.
mikea100
Jul 15 2011, 11:36 AM
Jon,
let me know when you're going to work on it, Ill stop by and help you or just hang out.
Mike
QUOTE(Jon Fernandes @ Jul 12 2011, 10:13 PM)
